Where can I buy replacement screen
who sells replacement parts?
좋은 질문 입니까?
Hi @cyberrescuers,
Here’s the maintenance and service guide for the laptop.
Go to p.13 Item #4 or p.14 Item #1 to find the part numbers for the LCD panel for the non touchscreen and the touchscreen model variants for the PC.
If you search online using only the part number appropriate to your particular model variant you will get results for suppliers.
The manual also details the necessary pre-requisite steps and then the procedure to remove / replace the panel.
Hopefully this is of some help
해당 답변은 도움이 되었습니까?
The issue with these Stream devices is cost :-(. Parts cost as much as a used one, or about as much as a new one on some of these.
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 54
댓글 2개
Hi @cyberrescuers ,
What is the full model number of the laptop?
jayeff 의
@jayeff I have a stream 13
klarenceray 의
