주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Fujifilm X100T는 2014년 후반 Fujifilm Corporation에서 출시한 X100 시리즈의 3세대 카메라입니다. 블랙과 실버 두 가지 색상으로 제공되며, 전면의 대문자 T로 식별할 수 있습니다. Wi-Fi 기능을 지원하며 1,600만 화소 사진 촬영이 가능합니다.
X100 F bottom plate replacement
Hi!
I have to replace the bottom plate od my x100F. I have watched X100T dissesembly guide on this site. It is not clear do I have to peel the leatherette or do I just remove the six screws at the bottom of the camera with the leatherette on. Did anyone took appart the x100F?
Thank you
Neven
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 3개
가장 유용한 답변
I took both cameras apart and removing the bottom plate of the X100F is way easier than with the X100T. You just need to remove 5 screws in the bottom. One at the battery compartment and the four remaining ones on the opposite side – leave the two at the tripod mount where they are for now. You can then remove the bottom plate. If you need you can unscrew the tripod mount to move it to the new bottom plate.
Since your post has been here for a while this might not be of interest to you anymore, but maybe it is helpful for somebody else in the future ;)
Cheers
Chris
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hello Chris, thanks for you answer. I did found someone who made the replacement but still I am sure that one more screw must be removed, the one on the side of the camera (the one with the focus selection lever. Please verify it, so people do not wonder about it, if they have to do it.
Cheers
Neven
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
My apologies, I suppose you are right, Neven. I will remove the bottom plate in the evening to verify. Maybe I take some pictures and post them here.
의
Hi Chris,
Have you had a chance to verify it?
Thanks,
M.
의
댓글 달기
How do we buy a replacement base plate?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I am selling mine. It has slight marks on it (that is why replaced mine.)
의
댓글 달기
답변을 추가하세요
Neven Miškulin 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 38
전체 시간: 1,296
