주요 콘텐츠로 건너뛰기
13인치 디스플레이가 장착된 MacBook Pro 모델에 대한 수리 정보 및 가이드.
9742 질문 전체 보기
AirPort and Bluetooth not available after repair
Because my clutch cover was seriously cracked, I decided to replace it, using the guide on this website. All went well -I thought- but when I restarted the macbook, AirPort and Bluetooth are not available.
What I did:
- checked all the connectors twice
- PRAM reset
- SMC reset
- Restoring the permissions on the hardddrive
Now I'm lost. Did my macbook just die on me or is there just a simple solution? Help is very much appreciated!
답변되었습니다! 답변 보기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 -1
댓글 달기
답변 2개
선택된 답변
Have you checked the connectors on the airport/bluetooth card? On this model it sits in the display frame, under the clutch cover. Chances are that something is amiss there.
해당 답변은 도움이 되었습니까?
점수 2
댓글 1개:
I tried that, but visually nothing seems to be wrong. Strang thing is that the fan keeps spinning at max speed. When I close the lid the macbook shuts of, in stead of going to sleep.Any thoughts on troubleshooting this?
댓글 달기
first try to remove the camera cable from the log board then check your laptop working normal or not . if the laptop behaving normal then the problem is in the cable or you have done something wrong . then try to remove the cable from the bluetooth board and clean all the jacks and reconnect them all . this may solve your problem
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Edwin 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,104
