주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Tahoe 리미티드 에디션을 제외하고, 이 차량은 2000년형 모델을 위해 새로운 GMT800 플랫폼에서 재설계되었으며, 풀사이즈 픽업트럭 및 SUV와 플랫폼을 공유했습니다.
Speedometer doesnt work or sticks
speedometer doesnt work
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 3개
what engine and what type of tranny do you have?
의 공유
I have the same problem with my speedometer not marking when the truck warms up. It marks on cold mornings but then stops after about 20 minuets. I changed out speedometer and speed sensor. And the problem persists. Any help would be greatly appreciated.
의 공유
2002 gmc yukon denali AWD speedometer not working Had new stepper motors put in cluster new speed sensor in transfer case new abs wheel speed sensors put in both fronts. no problems with transmission shifting . cruise control works just no speedometer. the info center went out when it quit working when you have 1/4 tank of fuel says you can go 0 miles on fuel, you fill tank up you can go 14.2 miles not sure what is going on with it.
의 공유
댓글 달기
답변 6개
선택된 해법
To avoid being accused of trying to alter your odometer, I would have this one repaired at the dealership.
이 답변이 도움이 되었나요?
점수 3
댓글 1개:
+1 for Mayer. The instrument cluster has "stepper" motors in them. This make and model are notorious for them failing. The dealership will perform a "sweep" test where they will use the computer and command the needles to sweep. If it fails the test, which it likely will, they will need to replace the cluster. Unfortunately the dealer doesn't offer parts for this. They will however take the old one and give you a remanufactured cluster. Expect to spend $350-$450 for the cluster and $100-$300 for labor.
의 공유
댓글 달기
I know it's an old thread. But this is a great link. It depends how involved you want to get on this project but for someone who isn't afraid of taring into things here you go
How to replace your stepper motors in the instrument cluster for some GM vehicles:
http://forums.trailvoy.com/showthread.ph...
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It's the stepper motor behind the instrument cluster, GM had a lot of problems with that. If you know how to solder , you can get a new updated motor for about 12.00 and solder it on. It's pretty easy .
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It is probably your Vehicle speed sensor. It is mounted on the tailshaft of the transmission and is held it with one small 8 mm bolt. Your speedometer wont work right and it will probably shift wrong or wont shift at all because the transmission relies on the speed signal to know when to shift. The tahoe/yukon use the 4l60e transmission.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I took my battery out to fix a hardline hose on my wiper squirter pump motor that cracked.
After putting the battery back in my speedometer was pegged out past 100mph!
Looked online at how to fix ……Ha Ha! Not pulling dash apart….
and thought all I did was take the cable off!
well I just had someone watch the gauge while I wiggled the
NEGATIVE battery cable (Alarm was going off and on) until it went back to 0mph!
I would try this FIRST! …… It CAN be that easy!
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Thanks,worked for me also,,my speedometer went to 100 after changing battery
This fixed the problem
의 공유
댓글 달기
if the speed needle doesn't work is the milage frozen or is it counted?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
t gabler 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 32
전체 시간: 46,892
