주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2, 2.26, 2.53, 또는 2.66 GHz Core 2 Duo 프로세서는 DDR3 RAM을 사용하며, 그래픽 프로세서는 설치된 시스템 RAM에 따라 128-256MB VRAM을 탑재한 FX9400입니다.
How to disable HD temperature sensor Mac Mini 2009
I just broke off the temperature sensor cable of the HD SATA board when putting in an SSD. It really looked like a spudgeable thingy, yet it wasn’t.
The sensor should be no longer relevant, but the system now thinks it is a Nuclear Power Plant core and turns the fans to a zillion RPM.
So my question is: how to fool OSX to think this sensor IS NOT THERE in the first place, and taken out of the equition to calculate the fan speed. No problem to Hex Edit some kext files.
Options I consider no solution are:
Installing MacFanControl. I did that, it helps a tiny bit, but only from 10 seconds after boot.
Connecting the 2 pins on the SATA board with some conducting material. It does not work.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
I would just replace the damaged board Mac Mini Interconnect Board - HD/Optical (09), Apple P/N 922-8807
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Blanka 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 454
