주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Support and repair information for Beats Solo3 headphones.
Left Side Trouble Working With Wire ONLY
Hi everyone,
I always use the wire with my headphones and didn’t have trouble with it until yesterday. The right side still works perfectly, but the left will only work if the wire is shifted in a specific way. For example, if I turn my head the sound on the left side will start and stop working several times. It’s hard having to stand completely still for the sound to work and sometimes it’s difficult to get the wire in a position that will work. I’ve tried it without the wire, using bluetooth, and both sides work fine. I also use the mic on the wire for online school so I would prefer to fix the issue rather than use bluetooth. I’ve had these headphones since 2017.
Any help is greatly appreciated.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
가장 유용한 답변
Hello, that’s a very classic headphone/earphone common issue, first you need to use another wire, if that doesn’t work then it’s the female jack port inside the headphone.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thank you so much for responding! I will try to find or buy a replacement wire and update after.
You're welcome, I hope this will solve your problem :)
Hola, donde consigo el cable y cual es su nombre
댓글 달기
답변을 추가하세요
Claudia 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 22
전체 시간: 413
