주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ryobi Cordless Brad Nailer P320 (2016)은 목공 및 건설 작업을 위해 설계된 다목적 도구로, 무선 작동 방식과 Ryobi의 One+ 시스템과의 호환성을 통해 확장된 사용 편의성을 제공합니다. 조절 가능한 깊이와 Airstrike 기술을 포함한 다양한 기능을 갖추어 여러 작업 환경에서 편리하고 신뢰할 수 있는 성능을 발휘하며, 문제해결 및 유지관리 기법을 통해 오랜 기간 기능을 유지할 수 있습니다.
How is this part not available?
My nailer took a tumble down the stairs and broke the metal bracket that the “no mar contact tip” attaches to (part of the depth set mechanism and the piece that sticks the furthest away from the body of the tool.) I've searched all the parts websites and it seems every o-ring and screw and other part is available, but I cant find this one and can't even find a good name for it. Not willing to buy a new tool over a $5 part. Can anyone help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개
I also have the same problem, the tip broke off. Can I buy the assembly which includes this part?
Steve
claretsfan@gmail.com
의
댓글 달기
답변 4개
가장 유용한 답변
Do you see the part on this diagram?
이미지
If so, this site should help identify it and may offer it for sale
It appears that that is part of the magazine assembly.
이미지
이미지
https://www.ereplacementparts.com/ryobi-...
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Thanks Issac, but no, it's not a numbered part on that diagram /website. It’s the metal piece that screw 36 goes into after piece 35.
의
@anonnimity Updated answer. Looks like it's part of an assembly, not sold as separate.
의
Ryobi OEM 79007001084 Nailer Driver Assembly R213BNA R150FSA R213BNE
의
It's called a "Work Contact Element" but part #79007001084 for the P320 does not fit on the assembly. Part 1084 has the same holes and fits on but it's a solid piece of metal. The one that broke on mine (Same as above) has metal grooves down the body and the width of the contact element isn't wide enough to slide over the nail tray. I've not found a replacement part the same as what broke.
의
The piece you are looking for is not marked and I'm having the same issue! it goes through 35 and is the piece that you attach the no mar pad to! Drop your tool and it breaks off. At this point I'm so disappointed that I am now in the process of replacing my Ryobi tools! Never by Ryobi they are junk!
의
댓글 1개 더보기
댓글 달기
이 답변이 도움이 되었나요?
점수 2
댓글 달기
It sounds like the specific part you're referring to is the metal bracket that houses the "no mar contact tip" and is integral to the depth set mechanism of your Ryobi Cordless Brad Nailer P320 (2016). Unfortunately, without a specific part number or a clear description, finding this part can be challenging.
One suggestion is to reach out directly to Ryobi customer support. They may be able to provide assistance in identifying the part and possibly ordering a replacement for you.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Mine was Part 42 here: https://ryobipower.ordertree.com/model?m...
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
sorry, was for trhe P321...
의
댓글 달기
답변을 추가하세요
anonnimity 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 42
전체 시간: 2,558
