주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dell U2717D 27형 디스플레이
Dell Monitor - Vertical lines - Stuck pixels?
Hi everyone!
I have a Dell U2717D monitor. Unfortunately, there are a few vertical lines in a spot of the screen. I’ve read a bit on the internet trying to find a solution. I’m used to repair screens that don’t power on (faulty capacitors), but not this type of problem (pixels).
First of all, the problem occurs even without connection to a PC. So, it is not a bad cable such as HDMI or DisplayPort. I can see the lines by powering on ONLY the monitor.
I’ve done the BIST test from Dell. The test puts a colored background such as RED, BLUE and GREEN. I can see that the lines alternate in colors. Sometimes there are more lines, sometimes less depending on background color. I don’t really know what to understand from this.
https://www.dell.com/support/kbdoc/en-ca...
I’ve disassemble the monitor to check for any loose connections inside. Unplugged and plugged back the ribbons, nothing has changed.
Is this case repairable ? What could I do ? Could the ribbons be defective ? Should I try to find replacing ribbons or they can’t be the source of the problem ? If so, where could I buy these (I’m from Canada) ? Is the problem inside the panel ? At this point, I believe that nothing could be done ? :(
This is a great monitor that works really well otherwise. I would really like to repair it.
I’ve already seen the following question: Vertical red line on Dell monitor. Stuck Pixel?
But, my problem isn’t solved.
What could be defective ? A ribbon cable ? The board ? Something inside The Panel LG LM270WQ5 (SS A1)?
Thank you very much for your help,
SaxGuit
이미지
이미지
이미지
이미지
이미지
이미지
이미지
이미지
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
That’s a TAB failure in this case - not stuck pixels. With TAB failures, there isn’t much one can do to repair them as the machines required are more than you want to know about and buying it to fix one display makes no sense.
In many cases with a TAB issue like this, the cost of the panel outweighs the cost of a newer monitor purchased brand new. You can still use these as test bench monitors due to how cheap they can be purchased, but unless the lines are barely noticeable it’s not an issue many can easily live with day to day.
이 답변이 도움이 되었나요?
점수 3
댓글 2개:
What exactly is a TAB failure ? I've tried to find some info about this just to understand better.
It's sad to learn that it is not repairable. It was such a great monitor!
의
@saxguit Tape Automated Bonding.
의
댓글 달기
답변을 추가하세요
Rémi Rousseau 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 9
지난 7일: 50
지난 30일: 252
전체 시간: 19,349
