주요 콘텐츠로 건너뛰기
2011년 상반기 모델, A1278 / 2.3 GHz i5 또는 2.7 GHz i7 프로세서.
782 질문 전체 보기
Anyone know what wires these are? MacBook Pro early 2011
I opened up my macbook pro for a clean and noticed some wires were cut except for one. I dont have any issues so Im wondering what these are for and if it is important to fix.
Anyone familiar with this?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 3개
You've lost your WiFi antennas! While you might get some connection you've not getting the full ability of the system.
Are you referring to my internet connection? My download/upload speed is excellent. How necessary do you think this is?
@mtamp - The antenna connections are severed so all you're getting is the small exposed wire end Vs the full antenna rail.
Think how your old FM radio would pickup distance stations clearly but after you broke the antenna all you could get was the stronger stations and it was not always clear. Thats what you face here.
댓글 달기
답변 1개
가장 유용한 답변
These are coax antenna wires which go to the antenna assembly within the clutch cover and connect to the AirPort board
You’ll need to take the display off so you can swap out the antenna assembly MacBook Pro 13" Unibody Early 2011 디스플레이 교체 and here’s the part Unibody MacBook Pro 13" Antenna Slide off the clutch cover to get to it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Mike Tampellini 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 40
