주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
모델 A1347. 2011년 7월 21일 출시. Core i5 또는 Core i7 프로세서 탑재. 썬더볼트 포트 지원. 이 기기는 Mac mini 서버 구성으로도 사용됩니다.
Not starting and Logic board debug
My a1347 Mac Mini has been turned off for a few years and now it will not start. When I press the power button the fan goes on for a second, the light goes on for about a second too and it makes some sort of sound. The sound is not the fan as I also hear it with the fan disconnected and I have some distant memory of that the sound always there on start.
I have checked that the power supply gives 11.8V on all 4 pairs as of this guide so it appears to not be the problem. Complete Dead - How To Check Power Supply Vs Logic Board
So now I am rightly of wrongly looking at the logic board. I have read in a few other forums of failing capacitors near the power supply on Macs. Can someone point out where in the photos these might be? Other ideas of where/what to check and how are also appreciated.
이미지
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 6개:
Did you replace the NVRAM coin battery?
의
No but I measured it to be under 3V. Is that enough voltage?
의
If the system had been sitting unplugged it will need replacing. I would start there.
의
I changed the old battery (2.9V measured) to a new one (3.3V measured) but it didn't help. Still the same when starting the Mac Mini. Any other ideas?
의
So can anyone point where the capacitors are on the logic board that are related to the power supply?
의
댓글 1개 더보기
댓글 달기
답변 1개
Sadly, as far as I know Apple never offered schematics and board views for the Mac Mini systems. So trying to nail down what is bad gets tricky! You’ll need to carefully inspect the logic board for burnt parts, staining or corrosion damage. I would give it a good clean as sometimes dust hides things.
Otherwise, it’s time for a new logic board.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Still, I can’t get this to start, for reference I have tried this
Measured the power supply both on the connector and the exposed pins on the board, 11.8V
Changed the 2032 coin battery
Cleaned the board with electronics cleaner
Tried the CMD-Alt-P-R combination many times.
Now I am considering a used logic board if I can find it for a reasonable price.
의
Also no obvious burns or corrosion on the board
의
댓글 달기
답변을 추가하세요
Alpaca 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 18
전체 시간: 514
