주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
My laptop can't boot
my laptop is ASUS X450C/X450CC. Before this happens, I can turn on this laptop normally i change my cmos cr23032 battery, bought a new adapter, change to ssd and change the keyboard . After I finish changing the keyboard and tested it. I can turn on and turn the laptop just fine. but after I screw all the motherboard screw. I can’t even boot up my laptop. is it possible that I made some mistake and short my motherboard or something? or did I damaged the power button, because not even any fans are spinning. can someone help me? thank you
Update (02/25/2021)
Okay, thank you. I will try to do it again.
이미지
here’s the current state of my laptop
i really don’t know what i did wrong but thank you so much for helping
Update (02/25/2021)
이미지
이미지
이미지
I tried to turn it on but nothing happens. Is it possible that shorted out the motherboard? thank you so much, mike for the help.
Update (02/25/2021)
이미지
I think this is what causes all the problems. I’m so sorry that I’m so stupid. I applied hot glue gun to attach the new keyboard and they’re so many glue tips that putting the pressure on the motherboard. maybe that’s what makes the laptop won’t start. I’m so sorry for the inconvenience. I really hope that I can find a way to revive this laptop again. thank you so much for helping, mike.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
Hi Afiq,
Yes wasn't a good idea. Cause and effect. So you weren't able to power on as you described "After I finish changing the keyboard and tested it. I can turn on and turn the laptop just fine. but after I screw all the motherboard screw. . ."?
Sorry I can't be of more help.
Good luck, Mike
@aactech thank you so much mike. I think the laptop is dead.
댓글 달기
답변 1개
선택된 해법
I don’t see how you could have damaged the power button. All you can do is take it apart again but re-assemble very slowly and carefully watching what you are doing. Take your time, look at and think about everything you are doing. Make sure all ribbon cables are connected correctly and carefully (probable cause of problem) and those that need to be folded away so there is no stress on the mainboard.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
답변을 추가하세요
afiq zaim 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 20
전체 시간: 907
