주요 콘텐츠로 건너뛰기
Voice activated wireless home audio system with Amazon Alexa built in for playing music, checking news, and other Alexa skills. The software for the Sonos One is updated through a Wi-Fi signal which is similar to other smart devices. Released 24 Oct. 2017. Model: S13 located on the bottom of the unit.
4 질문 전체 보기
Not powering on. Likely Power Surge issue
I had a power surge in my house & 2 of my Sonos One speakers (in the same room where I noticed the surge issue) are not coming on since.
I have tried to replace the cable with a working Sonos One from another room but no joy
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
My Sonos One SL's power supply died 2 months out of warranty. No support from Sonos, so I'm trying as well. Slightly different set-up. The seal on the base has two-parts: rubber and a plastic adhesive strip that covers the screws. Also, the 4 T8 screws in step 7 are covered with adhesive covering that needs to be pulled away from the chassis. I haven't removed the T8 screws yet as I don't have a T8 bit.
댓글 달기
답변 1개
가장 유용한 답변
Hi,
Open up the speakers and check for any damage i.e. burnt out components.
Here’s the ifixit Sonos One guides that will help to do this.
I cannot find the schematics or a service manual for the speaker so finding out what the problem is, especially if it is not obvious and then replacing any faulty part(s) if their value markings have been obliterated will be difficult.
If you can’t see any obvious damage or even if you can, post some close up images of the board where the power connects to. Here’s how to do this on ifixit 기존 질문에 이미지 추가하기
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
PC Chitalkar 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 13
30일 전: 59
전체 시간: 1,363
