주요 콘텐츠로 건너뛰기
2017년 9월 22일 출시. Model A1863, A1905. GSM 또는 CDMA / 64 또는 256 GB / 금색, 은색 및 스페이스 그레이.
873 질문 전체 보기
ONLY the backlight is working before AND after Display replacement
Hello,
I have a problem.
My Iphone 8 had a broken screen and the display no longer showed anything. Only when you turn it on in a dark room you see a glow, from which I conclude that the backlight still works. After I replaced the display, the same error still occurs. Can this be due to the logicboard? It was not my first repair, I already have some experience. Or are there any computer programs with which one can go on troubleshooting?
Thanks for all answers
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
Sounds like a motherboard issue, especially with the phone’s model. You may have to replace it.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
Hi, i had about 4 iphone 6 come in the shop in the last month where the iphone tries to turns on but only the backlight is on. Seems like a software issue. Install itunes to your computer if you don't have already and plug the phone in via lightning cable. If a pop-up comes up saying the iphone needs to be restored, restore it and it should work again.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
ImNotAnExpert 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 2
전체 시간: 23
