주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi 산하 브랜드 Amazfit의 사각형 플라스틱 스마트워치입니다. 2017년에 출시되었습니다.
Battery replacement on Bip
Does aynone tried to replace the batteriy in the watch? It seems my watch battery capacity reduced. Last depleeting cicle took only 15day but usualy it took 30-45day to drop to 15%. What kind of battery can be used to replace the original?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 달기
답변 5개
가장 유용한 답변
Replacement Bip battery
https://www.ebay.co.uk/itm/204240393865?...
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Hi there! The battery used on the Bip (model A1608) is a 200 mAh lithium ion battery. I’ve also been having issues with my Amazfit smartwatch regarding battery charge depletion. I think it may be something to do with your plug adapter or the fact you may have left it on the charger a bit too long after it reached maximum charging capacity.
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
I think it's the BMS. Mine drains in 5 minutes but you can still turn it on with long press. Then recharge for minute and it says 90% again.
의
댓글 달기
I suspect this is some software update result not really the battery. I already bought a bips and that have even shorter battery (tooks about 9day to depleet). So the old bip sits in its onw box. After about 6mo I checked what is the battery status and put on charger it was about 85%. If the battery would bad I suspect it would not even turned on.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
wher can i get amazfit bip u pro battery.???
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Battery replacement
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dimitryj Tyer 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 18
지난 30일: 83
전체 시간: 4,951
