I accidently spilt isopropyl alcohol into my controller
while i was cleaning my analog stick i accidently spilt isopropyl alcohol into analog stick and now its not working but when i put it into charger it flashes so plz help
좋은 질문 입니까?
좋은 질문 입니까?
Hi @amrmohamed ,
Was the battery was still in the controller when you were cleaning the analog stick?
If so do not attempt to charge or to turn on the controller as this may cause more damage
Even Isopropyl Alcohol conducts electricity when it is still wet and hasn’t yet evaporated. If the battery was still connected then the liquid may have provided circuit paths for the current that were not in the controller’s operating design and this caused some damage.
You will have to open the controller and inspect for any obvious damage to the components.
Here’s the iFixit DualShock 4 CUH-ZCT2 repair guides that may help.
When cleaning electronic devices either make sure that there is no power available to the device or only use a cloth lightly moistened with IPA 99%+ to clean to avoid excess liquid from traveling over the circuit board.
Unfortunately these days with a lot of electronic devices the power switch is not a power isolating switch.
해당 답변은 도움이 되었습니까?
While trying to fix stick drift I put disinfectant alcohol instead of isopropyl alcohol now my controller is not working is there a fix for this?
해당 답변은 도움이 되었습니까?
24 시간 전: 4
7일 전: 25
30일 전: 114
전체 시간: 4,953
