주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Logitech G933 Artemis Spectrum은 유선 및 무선 연결 기능을 갖춘 게이밍 헤드셋입니다. 2016년 10월에 출시되었으며, 모델 번호 981-000620으로 식별할 수 있습니다.
Sound Problem because of On/Off Dial
Hello,
I have the following problem with the headset:
The sound is sometimes very inconsistent. Example on a music track, I hear the music consistent but distorted, but the singing partly not and when it does as if it were coming from a distance.
However, if I now wiggle the on/off lever, it fixes the problems as long as it is in a certain position.
Does anyone know the problem and how to fix this?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 18
댓글 달기
답변 4개
가장 유용한 답변
Hi,
I had the same issue and I fixed it by cleaning the connection of the switch. If you look at my picture you’ll see the dirt causing the issue. I’ve also linked the video I followed. Hope this help.
https://www.youtube.com/watch?v=9r8KK3yn...
이미지
이 답변이 도움이 되었나요?
점수 12
댓글 5개:
What screwdriver do you use?
의 공유
@Solomon Salzman I just fixed mine today, following that video.. i used the iFixit bit "J00"
의 공유
I used this for my g935's worked like a charm. Just a heads up though those little flat pins on the actual switch aren't glued in and are tiny so use caution when cleaning. thanks for the video!
의 공유
This is the Fix for this problem, done it multiple times.
의 공유
You are Jesus Christ. Thanks. I was already thinking about changing headphones....
Today I found this article, did it, and solved!!! 😜
의 공유
댓글 달기
I can confirm this fix works.
I used fine tweezers to remove the switch cover, then used isopropyl alcohol, a cotton tip and a pointy plastic spudger to scratch off the dirt.
While in there, I removed the battery bay and dongle bay to add PTFE grease to the tilt hinges; this eliminated 80% of the plastic creaking noises
Before>>>
이미지
After>>>
이미지
이 답변이 도움이 되었나요?
점수 5
댓글 달기
Same issue. Cleaned the switch, sprayed some dry ptfe lube on, bent the metal strip so it tensions down a bit more on the slider and wham bam it works like a charm.
No more smacking the thing like a mad man XD.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
I used the guide from @alexandrec11706 but messed up and the power switch went flying across my desk because of carelessness. One of the 4 tiny metal contact points was lost. So I ended up soldering the contact points for the switch so that it is always turned on. PS: Remember to permanently remove the plastic switch if you go the solder route so it does not short. I've included a schematic of the contact points. Green Are the pegs you want to solder to keep the device in a permanent on state. Red is the off state.
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Dominik Traise 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 16
지난 30일: 89
전체 시간: 6,873
