주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
1980년부터 1991년까지 Nintendo가 생산한 60종의 휴대용 비디오 게임 시리즈인 Game & Watch에 대한 수리 안내서 및 문제해결 정보입니다.
Right button moves character left
I have an OCTOPUS Game & Watch that works fine except that lately, if I press LEFT once during the game, LEFT stops working and if I press RIGHT the character moves left for about 5-10 seconds and after RIGHT moves the character right again, the problem repeats itself. I did try to do a light cleaning with rubbing alcohol and although the buttons are more responsive, the problem didn’t go away. Has anyone else experienced this or know how to fix it?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 1개:
Did you also give the motherboard a light clean with the alchhol?
의 공유
댓글 달기
답변 1개
Im having a similar issue, except my left button doesnt work and the right button is spammed upon powering the g&w… i have parachute, so maybe theyre kickin the bucket after 40 years. :/
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Fixed it! Mine had residue from the carbon pads on the membranes. I just scrubbed contacts with some isopropyl with a qtip as a last ditch effort after checking all the test points with a multimeter. What i thought wouldve been corrosion, really turned out to be carbon and rubber gummed up. It looked clean, but turns out it was dirty. Good luck brotha
의 공유
IPA only on the board and button pads - NOT ON THE RIBBON CABLE.
ruined a donkey kong 2 erasing the connectivity pads of the black and white OG ribbon cable.
new ribbon cable on fleabay £20 macguy/canada - verified working replacement. gold coloured modern looking.
의 공유
댓글 달기
답변을 추가하세요
GameNWatch 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 20
전체 시간: 797
