주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xiaomi Mi 8 안드로이드 스마트폰은 Xiaomi, Inc.에서 생산하여 2018년 6월에 출시되었습니다.
No GPS after screen replacement
So after I replaced the display on my MI 8, the GPS is not working at all, everything else is fine (wifi and bluetooth as well). The new display came with the frame/housing as well, so I had to move the mainboard and all to the new one.
One thing is interesting is that it looks the new frame is missing a few contact points. could this be the problem? How can it be solved?
Photo:
이미지
btw, just to be sure, I moved back to the original frame + connected the new display, and this way the GPS is working fine. One solution would be to just take off the working LCD and apply to the original frame, but I’m afraid I’d broke the display while taking off…
Thank you
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
가장 유용한 답변
이미지
i notice two other differences as well. Not sure how significant they are. But its safe to say some or all.of these differences are what is killing your GPS. I suppose rather than breaking your new display, can you take the contacts off the old case and put them in the new one?
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
Unfortunately, these contacts cannot be taken off, as they are "part" of the (metal) frame.
의 공유
댓글 달기
I have the same issue on my device, tho I got mine in a used state and I dont know if the screen has been replaced (but I assume it is). Can you see where those contact pins are on the motherboard and add a small piece of tinfoil so they touch with the new frame?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Mate P 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 38
전체 시간: 1,127
