주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
동일한 모델 번호(A1932)와 EMC 번호(3184)를 사용하는 2018년 후반 MacBook Air의 소규모 개선에 대한 수리 정보 및 안내서입니다. 이 모델은 트루 톤 디스플레이와 약간 수정된 배터리가 특징입니다.
Left hand speaker muffled and staticy
Okay, my MacBook Air’s left-hand speaker is weird. It very very muffled and full static when compared to the right.
I thought it could be water damage and decided to replace it. I did that myself and it all went well and then went to check and no change on that speaker. It was the same as before not even a single change or improvement.
I ran Mac diagnostics, nothing came up. I also reset NVRAM/PRAM as someone had suggestion that might help. Still nothing. I’m at a total loss of what to do.
Also, I am 100% sure when I got it first it was working fine.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 2개
What do you hear when you plug in a good set of headphones in via the headphone jack? Use the balance control to bias which headphone is playing. Do you hear it with the headphones?
If you do then the MacBook Air 13" (Late 2018-Mid 2019) Audio Daughterboard or MacBook Air 13" (Late 2018-Early 2020) Audio Daughterboard Cable to the logic board is the issue. If its clean on both sides, then the logic board speaker cable connector has a problem.
Review this guide: MacBook Air 13” Retina Display Late 2018 오디오 보드 교체
Replace a torn or damaged cable connecting the logic board to the audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor. 이미지
제품
$19.99
Replace a corroded, dirty, or damaged headphone jack by swapping in an audio daughterboard containing the headphone jack and connectors for one speaker and the Touch ID sensor. 이미지
제품
$59.99
이 답변이 도움이 되었나요?
점수 0
댓글 5개:
Earphones have no problem with this. Only occurs when I use the in built speaker,
의
Look at the logic board for corrosion.
의
@danj I am pretty sure there was none since I did open up when replacing the speaking thinking that was the issue, and saw nothing much there in terms of it looking diffrent.
의
I think you'll need to bring your system into someone who has the skills to diagnose your issue. There is a limit on what I can offer for help.
의
@danj Thank you. Just wanted to exhaust all options before I did that in case it's something I can fix on my own. Really appreciate you taking you time to try and help me.
의
댓글 달기
I had the same problem with 2 Macs, the solution was to clean the grille with a dry/clean toothbrush. The issue was that the micro-holes were blocked, which can be confirmed by passing light through them.
I could diagnose the problem by connecting the speaker without installing it, I leave it carefully hanging and it sound really loud.
I attach a photo of the blocked micro-holes.
이미지
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
@oliversi - To many bread crumbs! 😆
의
it acted more like a cheese grater :)
의
댓글 달기
답변을 추가하세요
SeanErik 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 26
전체 시간: 777
