주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
GMC 브랜드로 General Motors에서 판매한 C/K 픽업 트럭(GMC Sierra 포함)에 대한 수리 안내서 및 지원입니다.
Rear running lights do not work?
The rear running lights do not work on my 94 GMC Sierra . My turn signals and hazards are fine. and brake lights work when I hit pedal , but my tail lights that stay lit while driving do not work and I have changed the bulbs already and no fuse is blown. Any suggestions?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
If fuses and bulbs are fine then check the switch. Make sure that it is supplying the running lights with power when selected. If not, and you've got power coming into the switch, then you need a new one. If it IS sending power to the lights, then you'll need to trace the wires back and make sure they aren't broken. If the power wires aren't broken and you're getting power to the lights, then you'll need to chase down the ground.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
Wait so I have no tail lights or running lights and I have power coming into the switch but not out to the lights. And I just tried replacing the switch what next?
의
@kaidadehaven so you had power TO the switch but not FROM the switch? You replaced the switch and still nothing? Verify power is coming from the new switch first. Then see if there's power at the lights. Could be a broken ground or broken power wire.
의
댓글 달기
답변을 추가하세요
Von 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 39
전체 시간: 3,890
