주요 콘텐츠로 건너뛰기
An Acer Aspire 5100 Laptop with a 15.4" inch display.
36 질문 전체 보기
Can I replace the ATI Radeon Xpress 1100 with something better?
So I wanna replace the ATI Radeon Xpress 1100 in my Acer Aspire 5100 to increase the performance in it as Windows Vista says it’s pretty good except for the ATI Radeon 1100 performance which it rates as only 2.1, anyone know how or if i could?
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi Valoris,
It is not really worth doing it for a laptop that old. The hard drive has an IDE/PATA interface so upgrading to an SSD drive is not really an option. Is your RAM the maximum 4GB? If yes that’s it . If no then you could upgrade. That’s about it.
해당 답변은 도움이 되었습니까?
점수 1
댓글 1개:
More info regarding RAM upgrade:
https://www.compuram.biz/memory/acer/not...
A SSD drive could make a difference. If drive is SATA then definitely yes but if PATA (IDE) then only maybe.
댓글 달기
Valoris Akosos this is a late answer used just for clarification. The video card on your computer is integrated into the motherboard. You can’t upgrade the card It is actually a chipset on your board). At this time you are stuck with what you have.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
귀하의 답변을 추가하세요
Valoris Akoso 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 62
