주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
ANKER SoundCore는 블루투스 스피커입니다. 모델 번호: A3102011/A3102014
Anker SoundCore Sport XL Disassembly
I have an AnkerSoundCore XL. It’s no longer charging and I’m trying to replace the micro USB port by follow a guide for a similar device, the Anker Soundcore.
The front of the Anker Soundcore Sport XL is different. It seems like there are allen screws in them, but I can’t tell if they’re for show. No standard allen key seems to work.
Does anyone know how to disassemble the Anker Soundcore Sport XL to replace the micro USB port? Will the guide below be similar steps after removing the front?
ANKER SoundCore 충전 포트 교체
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 5개
So, I have the same speaker with the same problem regarding the USB charging port (mine has a bad connection, is very loose). I found out how to open the front: you can slid a knife between the hard and soft plastic parts - no screws needed there - and then the front lifts up rather easily. I found a youtube video which is a bit blurry at the beginning but that’s how I got the idea, I hope it works to place a link here: https://www.youtube.com/watch?v=AFuO3JlK... Sorry, my English isn’t perfect, don’t know how to describe it better. I haven’t proceeded any further yet. Would be interested in your repairing results/process if you have any :)
이 답변이 도움이 되었나요?
점수 0
댓글 달기
It just pops off, get a knife in under the grill and it'll slowly come off, the Allen key things are for looks. Then there's lots of screws, easy enough. The central piece is just rubber, carefully get that off. You should be able to get a knife or such between the outer rubberised body and the plastic thing the speakers are attached to, that will pop up. You can then detach all the wires as they're plug types usefully.
I'm a little stuck at getting the charge port itself out, but is will only be a matter of time before it bends to my iron will!!! Lol, good job I didn't put a Y in there lol. Anyhow, there ya are for anyone who wants to try this
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Hi there, no problem putting everything apart (just few plastic pins got broken 🤬) but I still have problems reaching the charging port, I don't want to brake the lid but I can't understand how it cames off. Anyone of you does have any tip?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
If it is still of interest for someone, I uploaded two images regarding the disassambly of the charging platine.
The green mark show the position where you can place some tool to level out the charging platine.
Make sure to use only gentle force, to not break the extension that holds the screws.
The plate is glued at the bottom, so you will hear a noise indicating that the glue comes loose.
I was able to disassable it by levering a little bit on the one side, then the other and repeated until it came apart.
이미지
이미지
Cheers,
Daniel
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hola Daniel, sera que en algun lugar puede conseguir toda la piezas de carga?? tiene algun enlace o alguien que la venda??
Repararla ya n o es posible.
의
댓글 달기
Hello, I have the same speaker, when I turn it on the blue light turns on and the 3 white lights blink. however after 3o seconds it just turns off by itself. my charging port look fine, I dont know if its a battery problem or something else. Does every one in the thread had the same problem?
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
Hi Damien, I just got a broken one and I think that this could be battery related. My issue was charging related, but it was ultimately caused by a dirty usb port. If I were you I'd check battery connection. Luckily it's pretty easy to access. Just follow the guides above to remove the speaker grill, and then you can remove the left speaker (or both). Remove the four screws, and then you'll need a thin spuger, or guitar pick, to pry the speaker out gently. From there you'll see exactly where the battery connects to the main board.
의
댓글 달기
답변을 추가하세요
Veng 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 48
전체 시간: 2,713
