주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2020년 10월에 출시된 새로운 iPad Air. A14 Bionic 프로세서, 10.9인치 화면, 새로운 디자인, 전원 버튼에 내장된 Touch ID 센서를 탑재했습니다.
Touch ID Button Replacement
Dropped my iPad Air 4the Gen square on the Touch ID button and it will not recognize fingerprints any longer. Not finding a replacement part for this item. How can I get this fixed?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 2개
I am having issues actually finding a replacement button. The button itself is cracked and piece broke off. Any suggestions there?
May just have to bit the bullet and take it to apple.
의 공유
You can find these on ebay
의 공유
댓글 달기
답변 5개
가장 유용한 답변
Touch ID is one of the hardest things to restore. I am not sure about iPads but there are programming tools such as the JCID that can copy the codes that pair your button to the logic board, then write them to a new home button. This should do the trick in getting a replacement home button’s full functionality back.
Most components in apple products are paired with the logic board and either stop working or disable features after the pair component is changed. Again there are programming tools, I use the JC V1S myself on iPhone repairs, but I have not looked into iPad programmers.
Hope this helps :)
이 답변이 도움이 되었나요?
점수 2
댓글 6개:
Almost! The original button needs to be readable! Often they aren't after being damaged.
Best to take it to an Apple Store and let them fix it as they have the magic tools to do it.
의 공유
Fixed many a home button, even cracked ones, if the flex is good and the damage is to the outer layers there's a high chance of it working. Plus who doesn't want a JCID device to play with XD
의 공유
@eazy_pc_repairs - What can I say you have the skills! ;-} Most DIY don't ;-{
의 공유
@danj It honestly, for some weird reason, never crossed my mind that a high percentage of posters are not professionals who do this day in, day out :)
의 공유
I have the same problem! But I don't need Touch ID at all, it's just that the button warms up very much, despite the fact that I disabled Touch ID! Is it possible to programmatically disable the Touch ID function completely or physically disable it, but to make the power button work? @eazy_pc_repairs
의 공유
댓글 1개 더보기
댓글 달기
Took my iPad Air 4th gen in today to a repair store. My problems were bent frame resembling a ~ , cracked glass, lcd was OK, power/Touch ID sensor was cracked and broken as well as getting extremely hot to the touch. All said and done I was quoted $125. This is to replace the power/Touch ID sensor unbend the frame and apply a clear zag protective restorative film to mend the cracked glass as well as re-seat and re glue and make it resistant to further damage. All in all not bad imo. Thanks for reading.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Unfortunately Touch ID is paired to the iPad Air like with most apple devices unfortunately even if you were to replace Touch ID button yourself it still wouldn’t work because it wouldn’t be paired the only way to do this is with special tools only apple authorized repair centers have
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
@nicholaswiding Hi, Touch ID itself I don't need it, I just wanted you to cut it down completely, because the button warms up a lot. Can I turn off the Touch ID ribbon cable to make the power button work? What do you think? Thanks
의 공유
I have the same ıssue. My Touch ID doesent work and button warms up a lot :/ I wouldnt buy apple after that
의 공유
@amur221 Did you cancel Touch ID function ? If you did can you say how you did ?
의 공유
댓글 달기
I'm having the same problem, did you find a solution? My battery is draining so fast because of my cracked touch id button.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
would swapping the tiny chips from one touch id (broken) to second hand one ??
thanks
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
czadra 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 33
지난 30일: 148
전체 시간: 16,201
