주요 콘텐츠로 건너뛰기
A portable Bluetooth speaker manufactured by Ultimate Ears.
60 질문 전체 보기
UE MEGABOOM only working when plugged in
Had my speaker for over 2 years now but the charging light stopped working suddenly. The speaker is now stuck at 40% charge and stops working as soon as the charging cable is pulled out.
When I took out the battery and then plugged in the light started blinking but when I inserted the battery again it's still the same outcome.
I have read all the previous questions posted here about this issue and none have a solution. Can I play my speaker like this only plugged in?
Is it bad for the speaker to run on only the wall electricity? as the battery or current going to battery is not working.
Update (06/02/2021)
Any help would be appreciated please guys
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Try replacing the battery and check if that resolves the problem. Even rechargeable batteries have a lifespan
here’s the Ifixit Logitech UE MegaBoom Battery Replacement guide that will help.
Replacement batteries are available online. Just search for CS-LOE116XL to get results.
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It sounds like the charging port is bad or it has some sort of water damage.
해당 답변은 도움이 되었습니까?
점수 0
댓글 1개:
I'm sure there is no water damage. Is there any way to fix the connection between the battery and the usb charger?
댓글 달기
귀하의 답변을 추가하세요
Animesh 7 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 5
7일 전: 9
30일 전: 38
전체 시간: 322
