주요 콘텐츠로 건너뛰기
The Sony Cybershot DSC-W55 was released in early in the year 2007. It is upgraded with a 7.2 megapixel camera compared to the previous model's 5.1 camera and has 56mb of internal memory.
Where is the reset button on the dsc w55
where is the reset button
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 2개
Sony Cyber-shot DSC-W55 LCD Screen SHOWING BLACK, ITS FLASH IS NOT WORKING
PLEASE HELP ME.
Show reset button on youtube video for my cybershot digital camera
댓글 달기
답변 4개
가장 유용한 답변
I believe that this camera does not have reset button. You can reset the Camera by either using the Initialize option from the Menu or removing the battery. The Initialize option is under the Setup Menu of the Camera. To reset the Camera, remove the battery, press and hold the power button for more than 15 seconds and then reinsert the battery. Hope this helps, good luck.
이 답변이 도움이 되었나요?
점수 4
댓글 2개:
Did not work.
What did not work? What are you trying to accomplish? What is wrong with your camera? You need to give a bit more info :)
댓글 달기
Well, Ithink there is a reset button. You can find it opening the battery & card lid. There is a tiny hole, you should press it about 3 seconds.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
go to any photo => click on "menu" button => setup=> internal memory tool => format=> OK :) that's all.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Yuen on your Camera and press menu go to setup and go to setup 1 and press initialize!
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
sean 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 36
전체 시간: 13,214
