Where is the reset button on the dsc w55
where is the reset button
좋은 질문 입니까?
I believe that this camera does not have reset button. You can reset the Camera by either using the Initialize option from the Menu or removing the battery. The Initialize option is under the Setup Menu of the Camera. To reset the Camera, remove the battery, press and hold the power button for more than 15 seconds and then reinsert the battery. Hope this helps, good luck.
해당 답변은 도움이 되었습니까?
Did not work.
What did not work? What are you trying to accomplish? What is wrong with your camera? You need to give a bit more info :)
Well, Ithink there is a reset button. You can find it opening the battery & card lid. There is a tiny hole, you should press it about 3 seconds.
해당 답변은 도움이 되었습니까?
go to any photo => click on "menu" button => setup=> internal memory tool => format=> OK :) that's all.
해당 답변은 도움이 되었습니까?
Yuen on your Camera and press menu go to setup and go to setup 1 and press initialize!
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 7
30일 전: 40
전체 시간: 12,472
댓글 2개
Sony Cyber-shot DSC-W55 LCD Screen SHOWING BLACK, ITS FLASH IS NOT WORKING
PLEASE HELP ME.
sshankar789 의
Show reset button on youtube video for my cybershot digital camera
nagender.gunampalli 의
