주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Released in May 2020, the 13" MacBook Pro features quad-core Intel 10th generation Core i5 and i7 processors, and Intel Iris Plus integrated graphics. (Model A2251/EMC3348 with four Thunderbolt 3 ports)
What is this connection?
이미지
is this a broken connector? Took this logic board out to inspect (laptop nonfunctional) and among all these ribbon cables this is the only one without copper tabs to slide in and snap down on. This is near trackpad and battery side of the board.
Update (06/17/2021)
Here is the new connector type in the 2020 13” Intel MBP:
이미지
이미지
Looks like this 2020 MBP has a different type of connector: it’s a push-in ribbon cable trap with snap down bar. It looked like the end of the ribbon cable had been stripped away but what’s confusing is the new connection just looks like tape on the bottom side. A little peeling on the top side revealed a blue ribbon connection that could be pushed back in.
Many thanks to Dan for sharing pics of the older version. That it had a different connection there (that in this one certainly appears to be missing) led me to investigate further.
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 달기
답변 1개
선택된 해법
Ouch! Sadly someone lifted off the logic board connector with the ribbon cable.
Sadly, I couldn’t find any 2020 cable or logic board to show you the connector side. Apple changed their supplier and looks like they went with a shielded version given your image.
이미지
이미지
이미지
이 답변이 도움이 되었나요?
점수 2
댓글 2개:
Thank you. It turns out the connector on 2020 Intel 13” MBP (4TB) has changed. I edited my original question with more pics and left an explaining comment.
@yessammassey - That explains things! Very different interface.
댓글 달기
답변을 추가하세요
yessammassey 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 28
전체 시간: 618
