주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Xbox 360은 Microsoft에서 제작한 두 번째 게임기로, 2005년 11월 22일에 출시되었습니다.
Clean lens for xbox 360
How do I clean Dirty laser lens
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 6
댓글 달기
답변 4개
선택된 해법
well you have two options. You can try one of those cd's with little brushes on them or you can follow this guide then remove the four screws holding the drive together and from here you can remove the top case and take a cotton swab with a little bit of rubbing alcohol on the tip and gently wipe the lens off.
Hope this helped,
Cody
P.S. The second way will void any warranty you may still have on your xbox.
이 답변이 도움이 되었나요?
점수 6
댓글 1개:
also if you choose to open your xbox it would be a great time to blow the dust out of your xbox and give the inside a good cleaning.
댓글 달기
could I take my console to gamestop and have them clean it?
이 답변이 도움이 되었나요?
점수 1
댓글 달기
Most likely your laser will not be dirty, they really don't get much of a chance to get dirty as the drive itself is a pretty contained environment. You will likely need to replace the laser instead.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
This
Is very easy all u have to do is take some rubbing alcohol and a cotton bud.Next u put some rubbing alcohol on the cotton bud and start rubbing it across the lens and it'll be clean it really works
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Scott 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 32
지난 30일: 242
전체 시간: 58,042
