주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
LG V40 ThinQ 안드로이드 스마트폰은 2018년 10월에 출시되었습니다. V40은 LG 스마트폰 중 최초로 총 5개의 카메라를 탑재했습니다.
Does a replacement screen always include glass?
My LG V40 ThinQ has red burn in, and I was wondering if replacement screens always come with the Gorilla Glass, or is the OLED screen a separate item underneath? The outer glass is good so I'd rather avoid replacing that if possible. Thanks in advance.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The replacement always depends on the level of damage and the type of display your device has. Irrespective of damage the device having an LED display need to change the glass only. But, in case of AMOLED to Super AMOLED you are required to change the glass and screen both.
Explanation:
LED screen has a display glass on the top that displays the UI and beneath that screen, there is a tube-like LED light that provides the light to make the UI visible. So, in case of minor damage you are just required to change the upper display screen and not the LED screen beneath it. While on an AMOLED to Super AMOLED there is no backlight thing. They have tiny led bulbs integrated to display the color information as per UI. So if you damage your AMOLED to Super AMOLED, you are required to change the glass and display both as they are combined.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gary Benites 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 14
전체 시간: 268
