주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
The 5th generation BMW 3 Series is based on the E9X platform. The car pictured is a E90 chassis. The E9X chassis was used from 2004-2013 when the F1X chassis was released. When talking about a non-specific chassis, this generation is typically referred to as the E9X chassis since there are multiple chassis for this generation of 3 series, depending on the body style (E90/E91/E92/E93).
Why is my brake pedal solid with the vehicle is stationery
Have a strange brake pedal problem.
Good pedal when at standstill but with engine running pedal is to the floor and wont pump up. All fluid levels good and have bled the brakes with no bubbles. Vehicle is un-driveable. Can you help?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
가장 유용한 답변
Hi,
Check the brake booster check valve is OK or for a leak in the brake booster/brake booster vacuum hose etc.
Here’s a link that may help explain it.
이 답변이 도움이 되었나요?
점수 1
댓글 달기
I've encountered a similar situation before, and it turned out that the brake booster was leaking air. You can try stepping on the brake pedal several times when the car is cold - started, and then hold the pedal down while starting the engine. Under normal circumstances, the pedal will sink a little bit. If it doesn't move at all or sinks all the way to the bottom, there's a high chance that the brake booster is broken.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Alan Parker 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 2
지난 30일: 11
전체 시간: 189
