주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2013년형 모델로 2012년 10월 말에 재설계된 Pathfinder가 출시되었습니다. 2세대 Pathfinder와 마찬가지로, 프레임 바디 방식의 트럭 기반 SUV에서 벗어나 다시 한번 유니바디 디자인을 채택했습니다.
2014 Pathfinder Transmission issues
My dad’s 2014 Nissan Pathfinder recently started having what we beleive are transmission issues. as we attempt to accelerate it feels like the transmission is “slipping”, or put differently the car starts to shake a bit and it feels like power is not being applied to the wheels. we think its transmission related because when we put it in D or R it takes a moment and the car is almost like it’s in neutral before power is applied to the wheels. it takes 3-4 seconds now for the power to get applied, and then it feels like its “slipping” . i dont know if my description of the problem helps but its the best i can do. my dad said he reseached some info online and apparently this is a problem that nissan knows about but is not doing anything about to fix. he mentioned it might be a software related issue and had mentioned that some people had the problem fixed when a combination ofa valve was replaced with a software update. he said he already had the value in question replaced a while ago so im not sure what to do here. hes going to take it in but i'd love to be able to offer some helpful info as i fear this issue is going to be expensive. thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 5
댓글 1개
I have had issues with vehicles not shifting/accelerating properly when fluid levels were low. It is a very basic question I know but have you checked fluid level for the trans?
의
댓글 달기
답변 2개
선택된 해법
It is because of the solenoid failure. Need to replace the valve body and reprogram the transmission
이 답변이 도움이 되었나요?
점수 2
댓글 달기
I also had this problem on my 2014 and my 2015 pathfinder it’s the Nissan cut they aren’t the best I just replaced the transmission but replacing the transmission is professional level as you have to drop the whole front subframe (engine, transmission, ect.)
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
ryandasilva23 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 73
전체 시간: 3,141
