Missing Pads Charge Port
Hello,
I am missing charge port pads for pins 5, 12, 14, and 20 for an iPad 6th Generation WIFI. Can some help me identify any test points on board where I can jump these to the connector?
Thanks in advance!
좋은 질문입니까?
이 답변이 도움이 되었나요?
Thanks for all your help!
I am sorry, I missed to add another pad, the one right next to the purple one.
no problem, pict upgraded
hi can i you help me to pin point positive and negative pin to charge the ipad 6th gen beacuse the pin was destroy im trying put jumper on it
Hi @bryanlutuaco ,
yes, of course. unfortunately, it is difficult to post anything in the comments section :-) So start a new thread and throw a link (preferably by email - you will find it in the "about me" tab) so as not to miss it in the thicket of other messages.
지난 24시간: 1
지난 7일: 23
지난 30일: 64
전체 시간: 1,783
댓글 5개
you need to mark the pads in the photo or picture - the numbers of pins and lines are not marked on any of the available diagrams (let's at least set the starting point and the direction of counting - so as not to make a stupid mistake). At the same time, I confirm - such a check is possible
bert.harmidomski 의
I am missing the ones highlighted in light blue.
mmejia04 의
wait...
bert.harmidomski 의
mmejia04 post a picture of your actual board as well. That way we can actually see the placement of the components and follow the traces as per schematic....
oldturkey03 의
I posted a new picture, the pads inside the red boxes are the ones needed. The other pads are either connected to ground or have a second connection to the same point.
mmejia04 의
