주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Dualsense PS5 컨트롤러용 충전 거치대입니다.
How to remove the white side plates
The dualsense charging station has white side plates like the Playstation 5 console. I want to paint them black, so I was wondering if there was a way to remove the white plates. There are no visible screws. The whole thing seems to be glued together.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
did you ever find a way?
댓글 달기
답변 3개
가장 유용한 답변
If you turn the charging station upside-down, on the bottom plastic you will see two edges which connect to the inside side and top plastic which is one moulding. Pry the bottom plastic off (it's just clipped) and then undo the screws and the white side plastic comes off.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
See my teardown over at Dualsense Charging Station Tear Down Guide
이 답변이 도움이 되었나요?
점수 2
댓글 달기
So if you want to take the sides off your PS five you want to hold the PlayStation button press down and then up and then it’s off
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Sulakshan Rajaratnam 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 14
지난 30일: 52
전체 시간: 2,152
