How can I fix it?
I found the panda version of it on the street. Its pressure plate is stuck and the panda as well.
좋은 질문입니까?
좋은 질문입니까?
If this is a mechanized device and a coin is jammed, the mechanism is jammed. The may require disassembling the unit to reveal its internal mechanics to examine it up close. Whether gear or levers are used, sometimes its obvious where to reverse the mechanism to unstick the stuck coin. Good luck as this may result in damage as an inexpensive piggy bank. A rocket scientist isn’t needed as most parents have to deal with real world child raising issues more important than rocket science. Parents raise future rocket scientists.
이 답변이 도움이 되었나요?
I just received the cat version of this but when i press the plate it only says “Hello” and doesnt look out nor steal the coin. How do i fix it. Its my first time using this? Should i return it?
Using a fresh battery? If it doesn't operate, return it for replacement or refund.
지난 24시간: 1
지난 7일: 16
지난 30일: 51
전체 시간: 1,479
