주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Released November 2016, the PS4 Pro features upgraded hardware for 4K gaming and improved PSVR performance.
PSU replacement connector cable differences
Hi,
Recently the PSU on my ps4 pro blew (popped cap) so I got a new one, the previous PS4 pro had the ADP-300P1A PSU in and my new one has the ADP-300CR.
The new console was being very loud so i decided to swap the PSUs around but it appears that the small connector cable for each is different so I can’t swap them between consoles, does anyone have experience of this?
Thanks!
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
선택된 해법
Unfortunately Sony likes to release many different internal revisions of their consoles where they change only minor things. They look the same from the outside but have slightly different model numbers. You can only replace the power supply in your original console with the same model power supply.
The new one being noisy does not surprise me too much, see this quite often with PS4 consoles. Typically a result of either dust buildup in the heatsink, dried up thermal paste, or both causing the console to run hot and run the fan fast. It isn’t typically too bad to get the console apart to clean the dust out, if you are comfortable with trying to take the thing apart further I would recommend doing that.
이 답변이 도움이 되었나요?
점수 1
댓글 2개:
Thought that might be the case, guess i'm stripping down the new one and putting new thermal paste on tonight!
Does this mean I have to use the exact 4 pin PSU white connector cable that plugs into the motherboard for my PSU model? Isn't that like finding a needle in a haystack?
댓글 달기
답변을 추가하세요
theCBK 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 627
