주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2014년 10월 16일에 발표된 iPad Mini 3는 iPad Mini Retina(현재 명칭 iPad mini 2)의 후속 모델입니다.
New digitizer not responding
Replacing a touch screen and lcd on an iPad mini 3. Swapped original home button and on power up I get the unable to activate touch ID and the digitizer is completely unresponsive… old cracked one worked. Now I have tried 3 different digitizer and still no response. Any ideas?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
hello Jeremy,
You have to view again connection with a small interface. If You bought with, connection can be unsoldered. If without, that simply - check your soldering one more time. Sometimes, Chinese interfaces are just imitation. You can move your old interface into a new digitizer (I would do just that). That’s all about touch function. Home button - that pretty uncomplicated stuff: just two signals in one tape. Just check connection to the board (I assume you didn't break anything while disconnecting from the faulty digitizer).
이 답변이 도움이 되었나요?
점수 0
댓글 1개:
OK what about if I don't care about the original home button working. I also don't have the original lcd anymore which was never explained in any tutorial I have watched... all.just showed plugging the new one in. Any suggestions ? And yes home button still functions just no finger print sensor. Literally just the digitizer not responding.
의 공유
댓글 달기
답변을 추가하세요
Jeremy Trubilla 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 9
전체 시간: 251
