주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Canon EOS 60D는 18MP DSLR(디지털 일안 반사식) 카메라로, 회전형 LCD 화면을 갖추고 있습니다. 이 카메라는 2010년 8월에 출시되었으며, 카메라 전면에 인쇄된 EOS 60D를 통해 모델을 식별할 수 있습니다.
Canon EOS60D USB Interface Board Replacement.
My Canon EOS60D was on a tripod with USB cable in place. Tripod was knocked over and camera landed on the Port side, meaning that the USB plug hit the floor first. Since then the USB connection has not worked although all other camera functions are fine including HDMI interface and remote trigger.
Is it possible to replace the USB interface board and if so, how? I’ve looked at your guides and none go as far as accessing the USB board.
Thanks in advance
Harry Watson
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
선택된 해법
Hello!
Thankfully (since cameras are so pricey) they are generally repairable. However, parts can be difficult to find, especially for a camera of this age. Have you tried contacting either Canon support, or a local camera store? They will likely have parts, or be able to repair the board themselves. If they cannot, you could try to solder a new USB connector to the PCB. In the meantime (or if you determine it isn’t possible, too expensive, or too risky to try and fix the USB) try removing your SD card and read the data off of it.
이 답변이 도움이 되었나요?
점수 1
댓글 1개:
All this is good advice. Thanks for answering.
의
댓글 달기
답변을 추가하세요
Harry Watson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 1
지난 30일: 3
전체 시간: 386
