주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2019년 4월에 출시된 Huawei의 플래그십 스마트폰입니다. 6.47인치 FHD+ OLED 디스플레이, 디스플레이 지문인식 센서, 40MP 메인 카메라와 8MP 망원 카메라, 그리고 새로운 이어 피스 스피커 기술이 탑재되었습니다. 모델명은 VOG-L29 및 VOG-L09입니다.
No audio from bottom microphone
Hi all, I realised my P30 Pro’s bottom microphone stopped working. All apps that use this (Shazam, Google) pick up no sound from it. If I’m on a call, i have to wait between 5-10 seconds (which I think is when the top mic kicks in), then person can hear me. I have factory reset, cleared all caches but no luck so going to attempt changing the microphone/ SIM board. Has anyone done this before with success? On eb@y there are some boards that have this little silver IC in the middle of the board, and some don’t (this is on the opposites side of the SIM slot). Does anyone know what that is?
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 3
댓글 1개
I changed bottom board with microphone and still doesnt work
의
댓글 달기
답변 3개
가장 유용한 답변
Yes same problem I had. Changing the sim/mic board will fix problem.
이 답변이 도움이 되었나요?
점수 2
댓글 달기
You're on the right track.
This is exactly what the p30 pro does when the bottom mic stops working.
The mic is soldered on a small pcb that has the simtray on it.
Do inspect your part before installing it because I’ve seen alot of them being very badly refurbished for resale where the IC and stucked there with glue instead of being soldered to the board. It might be hard to see without a microscope, but I just want to let you know that that is a common practice with the P30 pro sim/mic board for some reason.
I hope this helps.
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
Thank you for your response. There are 2 ICs on that board, one close to the mic port and one in the centre of the board. Do you know which one it is?
의
I'm sorry, but I'm not sure I understand your question.
Just look at your board to see if the IC location matches what you are buying.
I think there maybe 2 version or so. That is because some countries uses dual sim, and some only uses single sim.
의
I get shasham and g-assistant to work, by letting a voice recorder run in the background
의
댓글 달기
이 답변이 도움이 되었나요?
점수 1
댓글 달기
답변을 추가하세요
theun4given1 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 41
전체 시간: 5,817
