주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Rakuten Kobo에서 제조한 e-리더를 위한 수리 안내서 및 문제해결입니다.
Kobo - Replacement button
I’m trying to find a replacement button for my Kobo Ereader, the rubber went brittle and crumpled :(
답변되었습니다! 답변 보기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 2개
What model is your Kobo e-reader?
의
It's a 2010 Kobo WiFi
의
댓글 달기
답변 3개
선택된 해법
Most of them have very generic buttons found in many devices, but usually requires soldering to replace them. Heat station and an iron would be requite usually.
If it’s the type of button I’m thinking about you may find some on digikey or amazon sometimes.
Can you send a picture of the button?
I hope this helps
이 답변이 도움이 되었나요?
점수 0
댓글 달기
Did you find a solution? I have a white Kobo 2009 (no wifi). The rubberized square button on the front has deteriorated and crumpled too.
https://kolico.ca/tmp/kobo1-IMG_20210916...
A closer look:
https://kolico.ca/tmp/kobo2-IMG_20210916...
:( This is a sad time for me.
Can anyone think of a suitable hack?
이 답변이 도움이 되었나요?
점수 0
댓글 3개:
I have the same problem, would love to hear a solution
의
Can we not get a replacement button or do we thrash the economy reader?
의
If it's the external button in the case, you might have some success making a replacement out of hot glue and / or a stiff bit of plastic - that what I'm trying
의
댓글 달기
Why does this say solved when it clearly isnt?
Same issue, same side of the button even.
I did find this, though it's not a soft button, but it's certainly an option? Haven't tried it yet though, need to talk to a friend with a printer.
https://www.reddit.com/r/functionalprint...
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Caitlyn Patterson 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 15
지난 30일: 121
전체 시간: 5,625
