주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Sony WH-1000XM2 무선 노이즈 캔슬링 오버이어 헤드폰의 수리 및 분해 정보.
Left speaker not working
Hi,
My left speaker stopped working. Touch is still working on the left side, right speaker works fine.
Can anyone advise which cables I should check/replace and Mark them in the attached image?
이미지
I have opened up the headphones.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 3개
Does the left speaker not work on wired mode(3.5mm cable), wireless mode(Bluetooth), or both?
의 공유
It doesn't work wired and unwired
의 공유
Hello,
Had the same issue with left speaker no longer working (after crackling for a few weeks),
The continuity of the wires was OK, however there is no continuity in the speaker itself once disconnected from the electronic board.
Do you know where to find a replacement speaker for hw-1000m2 ?
의 공유
댓글 달기
답변 2개
가장 유용한 답변
This sounds like a connection problem or a bad speaker. Can you take the circuit board and any protecting plastic off the left speaker cup?
이 답변이 도움이 되었나요?
점수 1
댓글 3개:
I should be able to do that. What should I look out for?
의 공유
@mrvolcan Make sure there are 2 wires connected from the speaker to the board. Make sure both of the wires have continuity from one side to the other. If both of those pass, comment both checks passed.
의 공유
I have the exact same problem. This evening the left speaker if my sony wh-1000xm2 decided to stop working. I don't know what to do.
의 공유
댓글 달기
I assume it is an connection problem between the pcbs on both sides. I have the same problem now with my headphones. I seems like there is no signal for the left driver. Anybody figured out the problem?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Moritz 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 50
전체 시간: 2,071
