주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
2017년에 Black and Decker에서 제조한 무선 휴대용 진공청소기입니다. 모델 번호 BDH2000PL로 식별할 수 있습니다.
Two items work only 30sec then switch off.
Dear friends,
I have two B&D 20v vacuum cleaners. Both of them worked exactly 1 year and then had the same issue: work only for 15-30 seconds then are switching off. There are multiples reviews on Amazon about the same problem, thus I think it is worth to try to fix or at least find what the problems it.
The battery pack is soldered to the controller, thus there is no easy way to replace any cell.
How should I start? I do have a multimeter but do not have oscilloscope…
이미지
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 1개
The battery pack is a 5 cell unit plus circuitry. The circuit monitors the cells during charge and discharge cycles. If one or more cells drop below a threshold safety voltage on discharge the circuit will shut down. The cause of the rapid drop in any one cell is due to ageing which is an increase in internal resistance and an inability to hold charge - a loss in capacity. If any one cell has aged all cells need replacing. They are LG HB7 units which need contact welds and soldering.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
El Persizki 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 5
전체 시간: 623
