Window won’t go up
Back window, behind drivers seat, window slipped down but won’t go back up
좋은 질문 입니까?
좋은 질문 입니까?
Suz Stewart, it is possible that the glass came of the regulator lift plate. As was already commented you will have to remove the trim from the door and take a look at the regulator etc. Here is the part of the service manual that deals with the window glass and the door panels and should help you with your repair. Jeep Liberty
해당 답변은 도움이 되었습니까?
It sounds like regulator is bad. You will have to take the door panel off and replace the regulator.
해당 답변은 도움이 되었습니까?
24 시간 전: 1
7일 전: 1
30일 전: 11
전체 시간: 292
댓글 1개
You're going to have to open the door up. Sounds like something slipped off inside.
brandon k 의
