주요 콘텐츠로 건너뛰기
The first generation (KJ) Jeep Liberty, a compact 4-door SUV. Sold in both 2WD and 4WD configurations.
33 질문 전체 보기
Window won’t go up
Back window, behind drivers seat, window slipped down but won’t go back up
이 질문에 답하기 저도 같은 문제를 겪고 있습니다
좋은 질문 입니까?
점수 0
댓글 1개
You're going to have to open the door up. Sounds like something slipped off inside.
댓글 달기
답변 2개
가장 유용한 답변
Suz Stewart, it is possible that the glass came of the regulator lift plate. As was already commented you will have to remove the trim from the door and take a look at the regulator etc. Here is the part of the service manual that deals with the window glass and the door panels and should help you with your repair. Jeep Liberty
해당 답변은 도움이 되었습니까?
점수 1
댓글 달기
It sounds like regulator is bad. You will have to take the door panel off and replace the regulator.
해당 답변은 도움이 되었습니까?
점수 0
댓글 달기
귀하의 답변을 추가하세요
Suz Stewart 님은 대단히 고마워 할 것입니다.
조회 통계:
24 시간 전: 2
7일 전: 6
30일 전: 10
전체 시간: 251
