주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Google에서 제조했습니다. 2018년 10월에 출시된 2-in-1 분리형 노트북 태블릿입니다. 모델 번호: GA00347-US
Google slate Battery replacement
Hello all, is anyone able to advise whether the battery can be replaced. I have been offered a Google slate which only works when plugged in.
Many thanks
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 1
댓글 3개
I just replaced mine and may have bricked it in the process. The batteries are glued in and require a heat gun to remove. It's not something I would recommend doing at this point.
의
I disagree with batteries being glued in place. However, double sided tape is used everywhere if not double sided thin foam tape. Gently prying up slowly with plastic tools made to reduce electrical damage and scratching, the batteries should come away to reveal the tape(s). Usually, most guides on disassembly to remove and replace rechargeable batteries give hints on where to pry and can be adapted to most factory installed batteries. Whether YouTube or steps including snapshots, there are plenty of diy procedures to have a feel of what to expect if tackling battery replacement.
의
EU Parliament has voted to ban the need for special tools to access batteries:
https://www.europarl.europa.eu/news/en/p...
의
댓글 달기
답변 2개
가장 유용한 답변
Those adhesive under the battery is really strong. Do it in a well ventilated area. I was able to turn the unit back on after replacing the battery!
이 답변이 도움이 되었나요?
점수 2
댓글 4개:
Where did you get the new battery from? Would you have battery part number?
Any guide to follow?
의
FYIOGXG Cameron Sino Battery for Google Slate
You should be able to find it on Amazon.
의
Did you use the motherboard replacement guide to replace the battery? or a video on youtube...
thank you
의
I followed the motherboard replacement guide here.
의
댓글 달기
How do you reconnect the display ribbon cables?
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Lordboot 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 50
전체 시간: 2,802
