Hey Alex,
Within 10 seconds of turning on my Xbox 360 S, even after not playing it for days, the light goes from green to red dot. No screen image or error message. Here's what I've tried to fix it but nothing has worked yet:
Checking power cord and box, and using a brand new one,
Checked all inner and outer cables/connectors,
Pulling out 250 gb hard drive, shaking and putting back in,
Taking Xbox apart and cleaning all dust from it,
Taking out hard drive and trying to boot,
Taking out CD drive and booting,
Replaced the fan with a Whisper quiet,
Unhooked the fan and let Xbox overheat so as to reset it (did exactly as DB said in his excellent video).
I've now got my heat sync and chip apart and will buy Arctic Silver 5 today and re thermal paste the chip and reassemble. I hope it works but don't expect it will because the red light comes on so fast, there's no time for it to be a heating problem.
If any serious tech out there reads this and can offer something likely to work, please do. I have no warranty and the box is about 3 years old (but has been well taken care of, well vented, cleaned, etc.
Okay, I did the Arctic Silver thermal clean and replacement idea and still a red dot. Now I'm trying the DB overheat reset idea again.
댓글 35개
Keep in mind that the red dot of death is not onlyonly caused by an error in your xbox360 Slim but can also be caused by an error I ur power adapter. If the power adapter light turns red after a few seconds or minutes, then the problem may lie there. If red, replace your power adapter to determine if it gives you the solution to renewed functionality. Otherwise if your warranty is still in good standing, seek out the R MA and return it to Microsoft. If neither of these solutions are an option for you, then click on the you tube link to follow it to a possible xbox360 Slim repair solution. Happy Gaming.
Nathalie Diaz 의
My light on my console turned green for a few seconds then red my power ADP went from yellow to green to yellow when powering on I took my heat sink off scraped all the sink clay into a pile on the CPU put my sink back on fixed!!!!
James patterson 의
I have the same problem with my X Box.I also had the black screen with a red dot in the middle of the power button
Jose Guillen Zavala 의
HERE'S THE YOUTUBE LINK. https://www.youtube.com/watch?v=p2-QSa2X...
GOOD LUCK,
Aaron Beaver 의
for the red center ring. xbox 360 slim
Aaron Beaver 의
댓글 30개 더보기
