주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
EOS 6D는 2012년에 Canon의 첫 보급형 풀프레임 DSLR로 출시되었습니다. 2.75”x2” LCD 디스플레이 패널, GPS 안테나 및 Wi-Fi 연결성을 기본으로 갖추고 있습니다.
Battery door is stuck
Help! My battery door is stuck, this happened because when I was trying to put the battery door back in, it got stuck somehow…
I removed it so I could put a battery grip on it…but when I tried to put the battery door back I accidentally got it stuck somehow, and it’s gonna be costly if I can’t get it fixed myself.
I uploaded a video to Youtube to show you guys what I mean.
해당 임베드는 잘못되었습니다. URL을 확인해 주십시오.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
@iangallagher looks like the spring for the locking tab isn't working. Try a very small screwdriver and inserted into the small gap, then push the locking tab in. If that does not work you may have to drill or otherwise remove the door and subsequently replace it.
의
댓글 달기
답변 1개
If you press on the door part does it flex downward? Basically seeing if the door is free just caught on the edge.
If it is then what @oldturkey03 suggested to carefully pry along the latching edge. Removing the bottom cover screws won't get you to the hidden one within the battery chamber. So consider that as you'll then need a new bottom cover and door vs just the door if you cut it out Battery Door For Canon EOS 6D Digital Camera & Bottom Cover Base Cover Plate Assembly For Canon EOS 6D Digital Camera
If there is no flex then it's possible something sticky got in the gap.
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Ian 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 10
전체 시간: 910
