Switch terminal failed, is there a way to unpot and fix it?
The potted aluminum "terminal" from the switch assembly of my grinder isn’t passing through the black wire’s conductivity. Is there anyway to unpot it, or if the components on the inside are well-known, so that I could repair it without unpotting it, such as bypassing it entirely with a jumper wire? Looks like it has some thin lines coming off of it to run a little LED light, so I wonder if that’s its only role.
Edit for clarity: The part number of the potted aluminum block(Plus the trigger and battery connector) is “202582001“ from the General Assembly Diagram on the page for the tool.
좋은 질문 입니까?
Weeve Ferrelaine explain this "The potted aluminum "terminal" from the switch assembly of my grinder isn’t passing through the black wire’s conductivity. " a bit more in detail. what are you referring to with the "potted aluminum"? Let us know what exactly happens to your angle grinder. You can even post images with your QUESTION to explain this a bit better.
기존 질문에 이미지 추가하기
oldturkey03 의
@oldturkey03 I updated the Question to include the part number. I tried a jumper wire, and it's working now, but still not sure if I'm missing capacitance, or other circuitry that may be crucial.
Weeve Ferrelaine 의
