주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Samsung Galaxy A71은 삼성전자에서 출시한 갤럭시 A 시리즈의 Android 스마트폰입니다. 2020년 1월에 출시되었습니다. 버전: SM-A715F/DS, SM-A715F/DSN(글로벌), SM-A715F/DSM(러시아).
Screen Issue Yellowish Pale Bright
My Samsung Galaxy A71 (Not 5G one) have a screen issue, The screen flickering and then become Yellowish and Brigther, Everything that usually black it become brown (such as Youtube Blank Space that doesn't fit / AOD / Samsung Logo when restart) First it's change from normal to yellow and then it's become permanent yellow full screen, flickering to normal sometimes or brighter and darker version. Everything looks pale and bright some sort of contrast maybe? I've try safe mode but it's still the same. I'm asking first because I don’t want to factory reset.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 달기
답변 2개
It sounds like you have either a bad display or an improperly connected display flex. Have you had the phone repaired recently?
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
No I haven't repair my phone before.
의 공유
In that case, you could take it to a repair shop so they can take a better look at it, or you could try replacing the display. However, with Samsung's phones, you have to go through the back to replace the front, and sometimes the back cover can break if you aren't careful.
의 공유
댓글 달기
Is there a fix for this issue? I have this issue rn. Usually screen turns black whenever i go through something black or when screen is hot
이 답변이 도움이 되었나요?
점수 0
댓글 달기
답변을 추가하세요
Gunsøu 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 18
전체 시간: 1,300
