주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
iMac Pro는 Apple의 지금까지 가장 강력한 iMac입니다. 3.2 GHz 8 core, 3.0 GHz 10 core, 2.5 GHz 14 core 또는 2.3 GHz 18 core Xeon W 프로세서와 함께 제공됩니다. EMC 3144 / A1862 (ID iMacPro1,1)
I want to upgrade RAM
I have an iMac Pro 2017 8 core 3,2 with 32 gig RAM (EMC 3144). Can I upgrade the RAM on this model?
there is no reference to EMC 3144 on the ifixit site
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 2
댓글 달기
답변 1개
가장 유용한 답변
We don’t have a guide to upgrade the RAM for this system. Apple made the design much harder than the regular 27” iMac’s which have a RAM access door. Here the system needs a complete teardown lifting the logic board fully out to gain access to the four SO-DIMM slots.
Unless you’ve done a bit of work on the newer 2013 ‘Thin Series’ onwards iMac’s so you are comfortable in taking the display off and have taken out the logic boards I would recommend you find someone who has, as this is an expensive system to get repaired if you make any errors.
OK I’m going for it!
First you need special PC4-21300 32 GB ECC Registered RAM iMac Pro Memory Maxxer RAM Upgrade Kit
Follow this guide to take the display off iMac Intel 27" Retina 5K 디스플레이 교체 the cable connections are slightly different than what this guide shows. Here’s a better image of the connections.
이미지
Review this iMac Pro 분해도 for guidance as the steps of removing the logic board as that’s all there is. Step 7 is as far as you need to get to.
Install 128 GB of RAM in your EMC 3144 iMac Pro. Compatible with 3.2, 3.0, 2.5, or 2.3 GHz Late 2017 iMac Pros. 이미지
제품
$731.99
iMac Intel 27" Retina 5K Display 디스플레이 이미지
안내서
난이도:
조정
30 - 45 minutes
iMac Pro 이미지
안내서
iMac Pro 분해도
난이도:
조정
이 답변이 도움이 되었나요?
점수 4
댓글 1개:
Yes to all of this. And yes to this is not a repair for folks who are inexperienced. It takes A LOT of doing, since the whole logic board needs to be removed, the DIMM slots are on the back of the board. But it's definitely plausible.
This is a procedure Apple will also do for you, but I would totally understand not wanting to take it to them since RAM will absolutely be pricey. And if it is a repair you can do yourself then why bother.
댓글 달기
답변을 추가하세요
Andrew Wessels 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 20
전체 시간: 1,716
