주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ford Explorer와 Mercury Mountaineer는 2006년형 모델을 위해 새로운 프레임으로 업데이트되었으며, Tower Automotive가 아닌 Magna International에서 생산했습니다.
AC only blowing heat
My blend door actuator started clicking and was stuck on AC. I finally just replaced the actuator and now I have heat but I now only have heat. No matter what I set the temp setting to it just blows hot air out of all the vents on both sides, driver and passenger.
이 질문에 답하기 저도 같은 문제가 있습니다
좋은 질문입니까?
점수 0
댓글 1개:
i have ford explorer model 2010. same issue of no cold air blowing
checked and found compressor clutch relay not energizing. while jumping he clutch relay contact ,compressor clutch engaging. seems some control logic blocking the signal to compressor clutch relay. anyone can suggest what are the signals blocking the compressor clutch from engaging?
댓글 달기
답변 1개
I would guess that there is still a problem with the blend door.
If it were “clicking” I would think the actuator was attempting to move the door, but something was wrong with the drive.
Or it could be that the actuator did not get installed properly.
이 답변이 도움이 되었나요?
점수 0
댓글 2개:
My only guess is there is something wrong with the new actuator. My setting was already set on cold so it started blowing hot before I messed with it. I’m not sure how it could be installed incorrectly. There is only one plug and the shaft only fits in one way.
Did you fixed the issue? Because I’m having the problem too
댓글 달기
답변을 추가하세요
Scot Williams 영원히 감사할 것입니다.
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 24
전체 시간: 1,271
